820-00281 - A. Not powering on
buritix
Hello everyone.
I'm new in the forum, and I am not a native English speaker so just in case I make mistakes writing, i'm using google translate.
I hope to find some help here, thanks
PP20V_USBC_XA_VBUS = 5.207 v
PP3V3_G3H_REG_R= 3.418 v
PPVIN_G3H_P3V3G3H = 4.886 v
PPDCIN_G3H_CHGR_R = 5.197 v
PPBUS_G3H_R = 0.029 v
Any history fault available?
Do you get the same behaviour on all 4 ports?
Compare diode mode readings on LDO outputs of all CD3215 chips; 1V1, 1V8, 3V3.
Be sure to use correct USB-C charger.
buritix
Change U3200 first; check if 1V1 LDO appears then.
Done i have already changed it and now in diodo mode 1v1 has 515 but it has the same behavior not 1v1 , in addition to that, i figured out that R3034 UPC_XB_HPD_RX and R3033 UPC_XA_HPD_RX has 0 ohm and the schematic shows that both 100kohms, i have already changed too for 100kohms , the board has the same behavior
Any reason to quote an entire text visible few centimeters above?
Do not hit Reply button, just write inside the down box.
Please, maintain forum aesthetic...
Did you really find R3033/34 in the board?
Appear like NO STUFF in the schematic; put back original ones.
Change U3100 now...
