Yes, steady image, when the problem occurs PPVOUT_S0_LCDBKLT is 0v
I also noticed that the power button is no longer working, SMC_ONOFF_L drops to 0V from 3.4V when the button is pressed, but nothing happens.
This looks like flexgate issue, if related with screen movement.
An issue with Hall sensors should affect image also.
But check LID signals, just in case.
I just tried opening and closing the lid several times but not all the way and backlight remained steady, as soon as I closed the lid all the way once backlight was gone.
How do I measure under the board with screen connected and battery connected? I have a test display but when testing that way with no battery the battery icon comes on and is gone in seconds and I cannot test this issue. For DP_INT_HPD I had to solder a wire to measure on the other side, I guess I will do the same, any tips are appreciated.
