820-00281: No booting up but CPU/GPU warm with fan spinning.
Sr. Robot
Hi, ive got an 820-00281 that does not boot (no image, no chime, no usb activity, no caps light) but it has fan spin and CPU gets warm.
If i let it cool down for a couple of days it turns on and works normal for a couple of minutes and then shuts down to after mentioned conditions.
Tried a completely different chasis, no change.
USB_C switches to 20v
PPBUS_G3H = 12.5v
PP3V3_G3H = 3.4v
PPVCC_S0_CPU = 0.68v
i tried chip from a working machine with clean ME.
It wont turn on with charger only (it gets the 20v). If i connect the battery i get the battery icon and wont boot.
Tried different 87w chargers but no change.
PPBUS_G3H is stuck at 12.36v. It is possible the battery is fully charged since i left it connected for a couple of hours
NO.
Try known good battery, just in case.
Be sure to connect battery data cable correctly.
Check the markings from its bottom side.
I soldered the OEM bios CHIP, same behavior,
I looked around to see if i moved any other component but everything seems intact.
12.3V means PPBUS_G3H is not correctly controled.
It must be 12.6v without battery.
Did you check on other machine if the charger is recognized as 87W?
"Be sure to connect battery data cable correctly.
Check the markings from its bottom side."
Did that?
Does it boot with a battery previously charged on other machine?
