820-00281 no power
Kyle93
Caps lock light comes on along with external video.
There was minor liquid damage on LCD connector. PP5V_SOSW_LCD was 0v, after replacing U9850 PP5V_SOSW_LCD now 5v but still no backlight
U9800 should be good, if you get external video.
You've said to have 12.5V at backlight output before.
That means EDP_BKLT_EN was high then.
DP_INT_HPD goes high now?
Really strange...
To get 12V on backlight output, Q8400 must be on.
That is possible if BKLT_SD is low (0V), which requires EDP_BKLT_EN to be present.
"EDP_BKLT_EN 0.31v"
Can you re-check?
