820-00281 no video
Kyle93
Arrived with no liquid damage. Customers claims screen just stopped turning on one day. No internal video but external works fine. Do not have a spare screen to test with. Its never been dropped.
What should be checked first?
Kyle93
New screen arrived and installed. Now have image on the screen but no backlight
PPVOUT_S0_LCDBKLT 0V 0.50 diode mode
What needs to be checked next?
Kyle93
Just checked and yes, there is image on original screen as well only missing backlight.
Should U8400 be changed? F8400 is good
PPVOUT_S0_LCDBKLT voltage (screen connected)?
Also check diode mode to ground; w/ and w/o LCD connected.
Kyle93
PPVOUT_S0_LCDBKLT 0V with screen connected
diode mode with screen 0.024
diode mode without screen 0.024
One of C8460-73 should be bad then.
Are many caps there, remove one by one and test each time if diode mode goes high.
Check first if any looks strange; remove that if is the case.
