820-00426 - charging circuit - U7100 gets warm
Rper123
Came in with U7100 blown. Replaced it, Q7130, Q7135, Q7155 and R7105 (measured kohm instead of 20ohm) also. U7100 got warm so I replaced Inrush Limiter mosfets from a donor board (in this model there are 2 mosfets but in schematics it shows only one - Q7180). U7100 still gets warm. Measured resistance on every pin on U7100 and nothing is wrong.
I tried charging the battery and CHGR_PHASE measures about 13,2V which normally is 12,6V.
"19=4,99V
20=4,6V"
Seems to have bigger difference than expected there.
Try abother ISL6259.
Be sure C7125 is OK.
"replaced U7100 and after plugging power"
NEVER do this again.
After replacing burnt component, check first in diode mode around it.
This "short" may not exist; is how the chip blocks high-side MOSFET, when detects a problem.
Did you check C7125?
R7121/22 can both burn only if bad ISL6259; less chance that C7121/22 get shorted at same time...
Rper123
I have checked in diode mode first :)
It seems that replacing U7190 (P5V1) was the problem all the time. Now stable 5,1V at P5V1_CHGR_VDD and P5V1_CHGR_VDDP.
U7100 doesn't get hot and the battery is charging.
Thanks a lot for your help (y)
