820-00597 21.5 2017 iMac crashes on wake up
grmacs
Hi there, if I let this iMac go to deep sleep, it either will not wake up from sleep or it will crash and restart. Sometimes the backlight comes on but screen stays blank. I believe I've seen this before a couple of times with this year/model and ended up with a new board and CPU to fix. Is there a known weak link with these? I've tested the ram extensively and thats good, passes hardware test, tried external drive ONLY. I inspected the CPU mosfets and put some fresh solder on some of those connections as some of the research I did suggested these boards may have a MOSFET issue.
I do see some kernel panics in the logs. I guess just looking on general insight if there is a weak link or not.
We know about similar problems caused by FDMF6808N on MacBook Pro machines, but didn't heard about such issue with FDMF5804.
Try changing them, just in case.
grmacs
I ended up swapping the CPU and it has been working fine and waking normally and without kernel panics.
