820-00597 locks up after short time during boot
It's U5210 I need to reflash, right?
Looking for a WSON adapter or I'll just solder wire onto chip pads I suppose.
Did a little more experimenting with it. Tried heat and cold around the GPU, no major differences.
It's booting into one of 3 states:
1. External monitor works, chimes, locks up 1/3 of the way on the boot bar.
2. External monitor doesn't work, chimes, no idea how far it gets because no monitor.
3. No monitor or chime.
Thanks!
Tom
Okay, I reflashed the chip with this bin file after saving a backup. Programmed and verified successfully. Doesn't boot, only get the first diagnostic LED. Is there a chance I got the board number wrong? I was inferring it from google searching for this iMac, A1418 EMC 3069.
Thanks. Yes, that's the same model number on mine.
I had no trouble flashing the chip, verified correctly. Checked all the solder connections, it ohms out properly. Are there any special steps I should do to make this clean ME version of the EFI work? Should I just dump the old data back in?
Found another dump which functioned. Unfortunately, the problems persist. Worth a try, but not related to a BIOS corruption.
What's a good next step?
