820-00687-a A1534 2017
lincev
hi to all, I have this motherboard with a problem that it does not turn on. I have tested the charging and battery connector and with another board it works perfectly. In the power pad I don't have 3.3v.
the history is it worked fine but from one day to the next it did not turn on again (this was a week ago)
Any help to know what measures to take and diagnose? I would like to know if it has a short or the CPU is dead.
thx u
edit: Sorry I was testing a new connector, in case it helps, the original usb-c connector doesn't work in case this damage could have caused a short on the board
Check diode mode to ground on J9600 pins.
Compare readings with good board.
If USB-C connector was bad, you may have damaged U3100, or even CPU.
lincev
hi again:
Point 21, 19, 17, I have value 700, 690, 701 at bad board, but with good board I have 1400, 1396, 1405
Did you check both boards with red probe connected to ground?
Also check without USB-C flex connected.
There are some components placed on the flex.
lincev
Did you check both boards with red probe connected to ground? no sorry with black.
with red:
bad board | good board
Point 21: 590 590
Point 19: 560 486
Point 17: 470 599
Point 15: 480 353
Point 13: 360. 354
Point 11: 500. 606
Point 9: 470 597
Point 7: 470 470
Point 5: 470 470
omg sorry I'm confuse, but I check this to J9600 connector of board without usb-c flex.
