820-00840 5V 0.05A on charger
ajdoc
Cant find any corrosion on board.
PPBUS - 0V (not shorted)
PPDCIN_G3H - 5.2V
BUF_SMC_RESET_L - 3.4V
SMC_RESET_L - 3.4V
PP3V3_G3H - 3.4V
LDOs value on both CD3215 are correct.
TBA_AUX_DET - 1.28V
TBA_VDDA/P - 5V
PPVIN_G3H_P3V3G3H - 4.78V
PM_EN_P3V3_G3H - 5.05V
Flashed U2890 but no luck.
Any other idea?
There is a problem on USB-C area then.
Check PPBUS_G3H with both charger and battery connected.
Also check all LDOs on both CD3215 chips; voltage and diode mode.
Compare with good board, if possible.
ajdoc
PPBUS_G3H with charger and battery connected 11.51V (20V and 0A on charger)
PPBUS_G3H with Battery only 11.50V
LDOs on both CD3215 are both the same and correct in diode mode and voltage.
ajdoc
Checked signals and voltage and all was OK.
Replaced SMC and all works fine.
Many many thanks for all the ideas :)
