820-00840-A 20V 44mA
Fanfwe
I have this board that have signs of liquid spill. It won't turn on.
CD3215 stuff works fine, I get 20V on the charger, so I have good PP3V3_G3H and PPBUS_G3H is present also.
But then I get no other rails, no S5, S4 and probably nothing else either. The enable signal for those rails all come from U7800, and it's not active.
So I've looked at U7800. It has good power input from PPBUS_G3H. The 3V LDO gives me 3.2V.
PP3V1_RTC however gives me 6mV. Measuring resistance to ground on it gives me 20 Ohms.
I don't know if this is normal or not, don't have a good working board to compare it to.
If this is a short to ground, then I guess this is almost hopeless. Few caps to check for short, and if not, then bad PCH ?
Fanfwe
OK thanks.
The liquid marks are not on U7800, just to make it clear. That area looks pristine.
But yeah, my action plan right now will be to remove the few caps on the PP3V1_RTC line and check if the short goes away.
If not, then I will reheat U7800, and if this still doesn't help, I will remove it and hope for the short to be gone, otherwise this will turn into a donor board.
