820 00840 A Not booting up randomly, no known water damage. Just stopped working after screen repair
lonelyworks
I got an a1708 that is not booting up after an screen repair. I'm a bit of beginner into this, but I want to learn. I started checking voltage with some of the known point and got these:
PPBUS_G3H 0.4mv
PPDCIN_G3H_SNS 19.88v
PP5V_S5 0v
PP3V3_G3H 3.40v
PP3V3_S5 0.1mv
SMC_ADAPTER_EN - 0V
SMC_RESET_L - 3.4V
SMC_BC_ACOK - 1.06V
PP3V3_s5 - 0V
It seems like ppbus_G3H is shorted. Not sure though. What does that mean and what should I do next ? Since I'm learning, it would be nice to have an explanation of what's going on if possible :D
Thanks !
Check diode mode to ground at PPBUS_G3H.
Read "HOW TO collection" thread, if needed.
If short, or low value, compare with the reading on big coils.
lonelyworks
Thanks :D
I checked with the diode mode to ground on PPBUS_G3H, got beep on all of the connection. All of them had a low value. I checked the big coils to ground and one of them didn't beep (L8410). I read the ''How to collection'' it helped understand. Let me know if I didn't understood something.
Forget not beeping coil.
You need to find a coil with the same readiing to ground as PPBUS_G3H (if exist).
Very likely dead CPU.
Remove U7210/20 (one by one) and check if PPBUS_G3H short disappear.
If yes, let the board to cool down and measure again ohm resistance to ground at L7210/20.
