820-00840 a1708 no boot ,no sound but There is backlight
tipoti
hello,
There is backlight but no apple logo. I tried with a different screen, same result. I removed the ssd and tried it, same thing. no boot ,no corrosion, no sound no boot only backlight is on and charging,
no corrosion
What can be the problem ?
What is CPU core voltage?
Did you check external video and USB activity?
Did you try known good BIOS?
Any history fault?
tipoti
L7210/20 PPVCCCPU_S0G : 1.0 voltage fixed
no display on external display
When I plug in the usb macos, I see that it draws 5volt 0.045A at the usb output. But the options do not appear on the screen.
I felt the heatsink was a little too hot
I haven't tried the bios
