820-00840 Intermittently working
hambook
Hey all, had an 820-00840 come in liquid damaged. Cleaned some corrosion away from the area surrounding the CD3215's and after that the board was working fine for a day. The next morning, went to go turn it on and it booted half way then the screen went black. Took the board back out of the case and found that every 4th or 5th time plugging in the USB-C charger it will turn on, otherwise it will sit at 4.95v 10mA. It only turns on if the SSD is removed though. Going to order in an SSD to have on hand anyway, but as far as the board goes I don't even know where to begin on something like this. Any help would be much appreciated!
Still corrosion somewhere.
Does the machine fully boot every time SSD is removed?
Test it with USB macOS.
hambook
Looks like it isn't actually fully booting, I get no image when plugged into the display and I don't get any flashing on a USB drive plugged in. When it does hit 20v it pulls around 560mA
