820-00840 no GPU vcore.
TCRScircuit
Super Moderator
Got a 00840 trolling me. Came in no liquid with a history of a dog biting it. First thing I checked was output on external. Nothing, Unplugged the screen and tried again. Nothing. This was with a genuine apple usb c to vga dongle. Checked CPU vcore... 0.94 volts. GPU vcore - 0v. Missing GTVR_FCCM. I thought it was U7100, replaced it with no change. PPBUS_S0_CPU drops to 0v every 30 secs then goes back up only near the GPU fets. I cant find a 00840 schematic so im using a 00875 schematic which is close. GPU is not shorted.
At this point, i dont know what more it can be. I'm guessing fets, but I dont want to put heat to that area if I dont have to. Anything else I can check before replacing the FETs and U7100 again?
TCRScircuit
Super Moderator
I'll check for USB mouse. Part of me thinks the GPU isnt talking to U7100 to enable vcore... crap boards
TCRScircuit
Super Moderator
USB mouse flashes for a brief second so something is defiantly up with POST and the CPU. Im guessing its not posting because of GPU vcore being missing. Now to what FCCM means I have no idea. Im going to look around at similar intersil/renesas chips and see if I can figure out what that pin does. I know its suppose to be 5v. Maybe the FETs are messed up. I dont know, but if the fets are messed up, the GPU could have gotten killed. Hard to say on this one. Ill keep digging.
TCRScircuit
Super Moderator
I give up. I checked the circuit high at low. Nothing. My only guess is the CPU isnt requesting GPU vcore. It has a SDA line that goes right to the processor. Anyway, this gets 4 min each side at 70c in the USC and if it doesnt work, RIP.
TCRScircuit
Super Moderator
So, FCCM is a apple term for ZCD enable - Automatic skip mode operation (ZCD) for light load efficiency. Irrelevant because we arn't even getting core voltage. Going to look at the PWM side of things now
TCRScircuit
Super Moderator
PWM 1 messed up. 5v to 0 and cycles. Cant get the SIC635 in the us so I will use SIC631s. Replacing all my fets plus the controller again.
You don't even know if the controller is being told to turn on. Serial data communication with CPU/GPU will enable the regulator. Maybe you get lucky but this is a bit more sophisticated than just measuring PWM output signals.
TCRScircuit
Super Moderator
It croaked about a millisecond under gpu load. Board bubbled up from a internal short near the CPU and one of the GPU fets shorted ppbus to vcore. RIP.
