820-00840 No PP3V3_G3H
Hi there. I have an 820-00840. No power. Stuck at 5v and 0A from charger. There was some corrosion around CD3215's so I replaced with brand new ones (from your store) as well as ISL9239 (new) and U6990.
PPVIN _G3H is 5V going into U6990 but there is no PM_EN_P3V3_G3H coming from ISL9239 even after replacing.
Where do I go from here?
Did you properly measure in diode mode???
P_IN: 5.117
AUX_DET: 1.272
VDDA/P: 5.017
SMC_RST_L: 0.000V
SMC_RST_IN: 0.001V
AUX_OK: 0.221V
CHGR_BMON: 0.000V
CHGR_AMON: 0.000V
U7000 has been replaced again (NEW), as well as another set of CD3215's (NEW) as well as U6990 (NEW). 5.19V on the charger pulling 40 milliamps.
PP3V3_G3H is 4.25V now. What would be causing this overvoltage? Where should I look next?
So now you get 5V at PM_EN_P3V3_G3H?
Corroded resistor on R6993-97 divider, will change 3V3_G3H voltage.
R6995/97 went high, or R6993/96 decreased values.
PM_EN_P3V3_G3H is 4.63V
R6993 tests good
R6995 good
R6996 good
R6997 good
P_IN: 4.63
AUX_DET: 1.155
VDDA/P: 4.633/4.632
SMC_RST_L: 0.000V
SMC_RST_IN: 0.001V
AUX_OK: 4.246V
CHGR_BMON: 0.005V
CHGR_AMON: 0.007V
