820-00840 power cycling
Kyle93
Arrived with no drop or liquid damage. Board power cycles from 0.01 to 0.06a
PPBUS_G3H is steady 13V but PP5V_S5 and pp3v3_S3 power cycle every few seconds. Not shorted.
Any ideas or sound like bad CPU?
Kyle93
u7650 replaced and R7662 put back.
Steady U7650 voltages
PP3V3S5 steady 3.4V
what should be checked next?
Kyle93
This board is having another issue. When the screen is closed, it will not turn back on when opened back up even though board is still running.
HALL_SENSOR_RIGHT and SMC_LID_RIGHT are low 0.160V.
SMC_LID_LEFT_R is normal at 3.3V
Replaced U5225 and changed flex for J6600 but no change.
Could this be a SMC issue? What should be checked next??
Kyle93
With R5257 removed the fan spins for a few seconds then the board turns off. Nothing else happens.
Already changed audio flex as mentioned in last post
Kyle93
New issue now even with R5257 put back in place. The board will only power on a few seconds to where the backlight on the screen comes on for 1-2 seconds then the board turns itself off drawing only 0.01a
What could cause this??
Board should start with lid closed; no image/backlight in such case.
Check if you moved something else on the board.
Test the board alone on the desk, only charger connected.
Also try starting in SMC bypass.
