820-00840
suzukigsxr1000r
shows battery replace now
replaced 3 new batteries and the battery cable still same thing
replaced the main board still same ?
is it touchpad related !!
very weird
Does it show X on battery, or percentage?
Post F7000 voltage with charger only, and charger + battery.
Check resistance to ground on SCL/SDA lines of battery bus.
I'm bit confused now...
Do you have two boards which report same issue with the same battery?
I doubt to be both boards bad; pretty sure battery issue.
suzukigsxr1000r
Have even 3 board installed and replaced 3 batteries so far
giving the same issue
replace now .
when disconnecting the charger it die right away .
could the battery cable the connecting the battery with motherboard do this !!!
If you have 3 MLBs, don't you have the original batteries for them?
These ones give the same error?
Or you get error only with "new" (fake) batteries?
suzukigsxr1000r
I have one original battery and 2 replacements one
I get the error with all of them .
the main problem was non working keyboard
the laptop was working fine with its original battery .
( turns on with battery only but non of the keys worked )
there was corrosion on the touchpad cable which prevented the keyboard to work . Cleaned the touchpad cable and keyboard
works fine now .
connect everything back now not staying on without
charger pluggged .
Could be all bad Batteries.
or Fu***** hunted MacBook .
Trackpad (SMBus 3) and battery (SMBus 5) are connected on different I2C bus.
So shouldn't give conflict.
Unfortunately, theory and practice not always correspond...
