820-00840
Received from someone that attempted to remove EFI lock with a Chip Card. Worked prior but didn't work after install.
Q3730 was knocked off and has been replaced.
ppbus_g3h - 13v
Good until pp3v3_s4 and pp5v_s4 - 0v. No short. (same before q3730 replaced).
p3v3_sus - 3.4v
r7020 - 20v
Drawing 19v .06 amps but after about 15 seconds it spikes to .22a.
When battery is connected it appears to charge and climbs to 2a.
q7030 & L7030 get hot and u3100 gets hot when using corresponding port. u3200 does not get hot when in use. Neither hot without batt.
No response to smc bypass.
Only other thing that shows on thermal is u3900 which only blips.
