820-00850 5V 0.10-0.4A Cycle
ChronoInfo
History no liquid damage board stopped work no reason
PPBUS_G3H pulse 7V - 12.30V
PP3V3_G3H pulse
Remove F7000 PP3V3_G3H 0V no pulse
Noticed only U3000 get hot with F7000 present (158F with thermal camera)
U3000 should be bad, if reaches 70 degrees Celsius.
That could be caused by bad/fake charger.
Check diode mode to ground on U300 pins; compare with good board, if possible.
All USB-C ports have exact same behavior?
Test them flipping the cable too.
Also check diode mode to ground on all big coils.
Don't forget L9080.
"PP3V3_G3H pulse"
Do you mean L6900, or L7660?
ChronoInfo
Don't forget L9080.
"PP3V3_G3H pulse"
Hello, Thanks
i don't have good board for compare, i've check all pins of U3000 pin 20 seem very low 0.044V diode mode
All USB-C ports exact same behavior and test flipping the cable
L7660 is very low 0.044V
L9080 diode mode 0.370V
for PP3V3_G3H pulse at L7660
Remove U3000 and check if diode mode reading on 3V3_G3H power rail goes higher.
If yes, test if board boots.
BTW, write directly into bottom reply box, instead of clicking Reply button.
Please, maintain forum aesthetic...
ChronoInfo
pin 20 when U3000 remove : 0.414V diode mode
Tried plug charger i've 5V 0.25A
now PPBUS_G3H 12.26V and PP3V3_G3H 3.32V stable
ChronoInfo
replace U3000 board recognized DFU mode but revive not work on Apple configuratorCapture d’écran 2025-01-27 à 17.00.13.png
U3900 heat above 33 degrees celsius
