820-00850 5V DCIN all LDOs present
Rlab
Hi guys,
I got this mac with a little water damage in the QB631 area and RB641 & RB631 were replaced.
I have 20v in DCIN only with the battery connected but it does not turn on. without the battery DCIN has 5V and all LDOs are present.
checking without battery i have:
PPBUS_G3H 12.28 V
PP5V_G3S 0.033 V
P5VG3S_EN 0.0 V
PP3V3_G3H_RTC 3.3 V
PP3V3_G3H 3.3 V
PP3V3_S4SW_SNS 0.0
PP3V3_G3S 0.0
P3V3G3S_EN 0.0
No shorts..
bad U7800?
any ideas?
Rlab
yeap, all USB-C ports have the same behavior. 20V with battery and charger only 5V just charger.
no shorts found, all diode mode readings are ok in LDOs.
CC1/2 pins. ? what is it?
anything else to check before the T2 firmware ?
Rlab
USBC_XA_CC1 0.569
USBC_XA_CC2 0.562
USBC_TA_CC1 0.566
USBC_TA_CC2 0.572
USBC_TB_CC1 0.559
USBC_TB_CC2 0.565
USBC_XB_CC1 0.557
USBC_XB_CC2 0.563
what do you think?
Rlab
yes, i have all LDOs present, 3.3 1.8 (X2) and 1.1 ( on each port where power is connected)
What could be the reason for 20V in DCIN when battery and charger connected but 5V with only the charger connected?
Rlab
2informaticos !!!!
mil gracias !!!
So the T2 firmware fix procedure did the magic.
This mac is now up and running. :geek:
