820-00850-A board with CC lines issue
sekidata
Board had minor liquid exposure in the USB-C area of the XA port. PPBUS was 80Ω to ground. I found a shorted speaker amp (U6550) and replacing it removed the short on PPBUS.
I replaced all components with possible corrosion in the USB-C area around U3100, including the CD3215. Now, all 4 ports are stuck at 5.1V 0.26A.
I get all LDOs on all CD3215s. No shorts on CC lines (good diode mode readings). However, I only get 1.1V on the PP1V1_UPC lines on three ports; the XA port is missing PP1V1_UPC_XA_LDO_BMC. I also see normal behavior of CC1 and CC2 on the three ports other than XA.
What could cause the CC lines to malfunction on a single port when there are no shorts or other obvious issues?
CC1/2 lines problems usually cause black USB-C meter; as the charger doesn't properly detect the laptop in that port.
You should change that CD3215 chip; try reballing first, just in case.
If the charger works in both ways on that port, then no CC1/2 issues there.
Check all resistors corresponding to that chip.
1V1 LDO only appears on the powered port.
Also CC1/2 lines from one port, are not involved on other port functionality.
Looks like you have problems with U3100 channel.
XA CC1/2 voltages when you plug the charger into XB port are really strange.
Just in case, reflash/replace U2890.
Check any power rail in that area (diode mode); even U2800's ones.
Be sure no broken trace, or ripped off components.
Another observation: when I connect a battery, I get the following depending which port I plug the charger in:
TA: 20V 0A
TB: 20V 0A
XA: blank USB meter
XB: 20V 0A
Without a battery present, I get:
TA: 5.1V 0.26A
TB: 5.1V 0.26A
XA: 5.1V 0.26A
XB: 5.1V 0.26A
Also, I got the machine to start up on battery power. It shows the battery percentage but does not recognize the charger at all. The battery is not charging.
Yes, both ways.
Note that I have replaced several CD3215s, all sourced from various donor boards. I now suspect that some of these were not fully functional to begin with... I will get brand-new CD3215s and replace all 4. Stay tuned.
After replacing all four CD3215s, the situation is unchanged. One additional observation is that the bus connecting the CD3215s together (I2C_UPC_) shows values around 2V on half of the CD3215s, and 3.3V on the others. Help!
