820-00850 board with 20V but no signs of life
sekidata
This 2018 A1989 board shows 20V on USB-C pulling 0.05A. No liquid damage. I have PPBUS_G3H at 12.6V and the SLP and AWAKE voltages are present. It is missing all G3S rails and their G3S_EN signals, which come from the PMU U7800.
What does U7800 require to produce the G3S_EN signals?
sekidata
The machine enters DFU mode but since all SSD power rails are 0V, the DFU Restore fails with the timeout error. I need to get my power rails restored first.
Check diode mode to ground on SSD power rails.
Many times, SSD and G3S voltages appear after complete DFU.
sekidata
The SSD power rails are all free of shorts. I'll try DFU Restore again with/with battery and with/without charger.
sekidata
No luck. I've tried 6 times to Restore/Revive and I always get the "gave up waiting" error. SSD and G3S rails are still missing.
sekidata
Mystery solved! I just did a gentle reflow of the PMU (U7800), just in case it was the problem point. This restored the SSD and all other power rails and the DFU Restore went through. I can't say for certain why this worked but the machine is up and running now.
