820-00850 dead 20v amp pulsing
yair37
PPBUS_G3H 12.2V stable
AWAKE and SLPS2R are pulsing with the AMP pulse..
PP1V8_SSD0 0V
PP2V7_NAND_SSD0 0V
PP0V9_SSD0 0V
PP3V3_G3H_SSD0 3.3V
yair37
LDO_CORE 1.5V
PP0V8_SLPS2R 0.8V pulsing.
PP3V_G3H_RTC 3V
PP1V2_AWAKE 1.2v pulsing
PMU_LDO3_OUT 1.8v
CPU_C10_GATE_L 0V
PP1V_S0SW 0V
LDO_RTC 0V
PMU_VPUMP 5V
PP3V3_AWAKE 3.3V pulsing
PP3V3_S5 0V
Maybe was broken/open; short (0 ohm) is its correct value!
Board still not turning on?
Check the other voltages, missing/pulsing before.
yair37
o.k i sew the problem:
NC_PP3v3G3W_PGOOD and NC_P3V3G3W_EN dots under U7800 was not connected, but i dont see where to jump from/where they goes...
yair37
the same except LDO_RTC 1.2v now.
LDO_CORE 1.5V
PP3V_G3H_RTC 3V
PMU_LDO3_OUT 1.8v
CPU_C10_GATE_L 0V
PP1V_S0SW 0V
LDO_RTC 1.2v
PMU_VPUMP 5V
PP3V3_S5 0V
Are you sure R7900 is good now (0 ohm)?
Check diode mode to ground at all small coils surrounding U7800.
Just in case, check all big coils too.
