820-00850 Liquid Damage to PPBUS_HS_CPU C7214 - 5v no Boot
Have an 820-00850 A1989 13" Pro 4 Thunderbolt Port.
Liquid damage to C7214 only, was totally burned out with burning electrical smell. Shorting to ground for sure.
Getting 5.1v on USB
No liquid to anything else.
Fried CPU?
Cheers
I measured at PPBUS_HS_CPU the first time, have just measured PPBUS_G3H and its the same.
Does that sound right or am I making a mistake?
PPBUS is the same, just separated with miliohms resistor.
If you still have short, is time to check now U7410/20/30.
I am getting 2.2 ohms on PPBUS_G3H with all U7410/20/30 off.
I removed them and re-applied individually with no change in ohms.
So currently I have U7210/20 and U7410/20/30 off the board and still have the short.
