820-00850 no camera
Sr. Robot
Hi, i got a 820-00850 with no camera, OS says camera not detected.
Tried known working LCD with camera and flex cable, same thing.
PP5V_G3S_ALSCAM_F: 5.1v
PP1V8_G3S: 1.8v
SEP_CAM_DISABLE_DFF_L: 1.8v
R5336 and R8508 look good and measure all right.
Diode mode to ground on data lines:
I2C_FTCAM_ISOL_SDA: 0.444
MIPI_FTCAM_CLK_ISOL_FILT_CONN_P: 0.435
I2C_FTCAM_ISOL_SCL: 0.433
MIPI_FTCAM_CLK_ISOL_FILT_CONN_N: 0.430
MIPI_FTCAM_DATA_ISOL_FILT_CONN_P<0>: 0.426
MIPI_FTCAM_DATA_ISOL_FILT_CONN_N<0>: 0.435
MIPI_FTCAM_CLK_P: 0.408
MIPI_FTCAM_CLK_N: 0.398
MIPI_FTCAM_DATA_P<0>: 0.405
MIPI_FTCAM_DATA_N<0>: 0.416
MIPI_FTCAM_DATA_ISOL_P<0>: 0.425
MIPI_FTCAM_DATA_ISOL_N<0>: 0435
MIPI_FTCAM_CLK_ISOL_P: 0.435
MIPI_FTCAM_CLK_ISOL_N: 0.429
Both R5335/6 OK?
Diode mode to ground at I2C_FTCAM_SCL/SDA?
Check the same at R5315/6.
Be sure L8502-4 have good continuity.
BTW, any history available?
Sr. Robot
R5335/6 measuring good.
I2C_FTCAM_SCL: 0.384
I2C_FTCAM_SDA: 0.382
R5315/6 also measuring good.
I2C_ALS_SDA: 0.408
I2C_ALS_SCL: 0.409
No history
Is the macOS installed normally?
I saw such problem using OpenCore Patcher, when installing new macOS versions, not supported in normal way.
However, this machine should directly support latest macOS I think.
