820-00850 - PP1V8_UPC_TA_LDOA reading 3v
Palhano
While it had battery power, the mac would turn on, but it wouldn't recognize the charger. I have 20v, the board starts to boot, pulls it down to 0.6v and restarts.
I discovered PP1V8_UPC_XA_LDOD reading 3v on the UB300. I changed it, but the problem remains. But only when the charger is in its USB-C, in the other inputs it has 1.8v. The other CD3215 have normal measurements
It does not have direct contact with the 3.3v line close to the CD3215
Any light?
Palhano
Sorry!
I was searching in another topic about the problem and I was mistaken with the line: PP1V8_UPC_TA_LDOA
Check C3105 voltage with U3100 removed.
You should have 0V.
If not, then you have lekage inside the board.
Palhano
Without the chip, the C3105 is zero. In OL diode mode. Good sign, right?
My CD3215 chip is over, I'm going to order it and try to change it again.
