820-00875 slow charging
Kyle93
No liquid damage. Board looks pristine. Arrived not fully turning on. After disconnect and reconnect battery it will draw 20V and charge the battery around 2.5a as it should but after unplugging and plugging back in a couple times it will go down to 4.45V and steadily charge the battery only at 1.49a
Tried pram reset but no changes. Tried known good battery as well.
What should be checked next?
Battery is always recognized by macOS?
Its percentage is showed correctly?
Check ohm resistance over C7020/23.
Run HWMonitor and check I/V sensors.
