820-00923 20v 0.0A No PPBUS
JdYoda
Hello everyone
Board came by liquid damaged and messed up by previous service. Some components are missing, dirty, CD3215 overheated etc. No voltage on USB-C meter at all
What is done for now:
Replaced all 4 CD3215
Replaced U7000
Soldered back missing U8000 and U7960
Soldered back missing Q7040 and Q7030
Now got back 20 volts, but 0 amps
PPDCIN_G3H 20 volts, stable
PPBUS_G3H 0.6-0.9 volts. No short
R7020 is ok, 0 ohm, 20 volts
R7021, R7022, R7061 and R7062 is 1 Ohm as it should be
U7000, Q7030 and 7040 as i said is already changed
Is it something else can pull the line to the groung, or u7000 still doesn't work properly by some reason?
Diode mode to ground at PPBUS_G3H?
Post U7000 voltages; P_IN, AUX_DET, VDDA/P, AUX_OK, A/BMON.
Be sure R/C7030/40 all good.
JdYoda
Diod mode for PPBUS - 0.42
u7000:
P_in - 20.0 v
Aux_det 6.6 v ( is it a normal value?)
Vdda/p - 5.0 v
Aux_ok - 3.4 v
Amon - 0 (diode mode 0.64)
Bmon - 0 (diode mode 0.64)
All elements around U7000 are good. No short/values equals the schematic
You should change U7000.
Do not expect miracles from this board, of liquid damaged and already messed up by someone else.
JdYoda
Yes, you right about miracles. But i just want to understand why ppbus is missing. Just collecting knolege and expirience piece by piese to my head :)
Changed U7000 one more time, AMON and BMON is still 0 volts. Other values also didn't changed
Is there something else i can pay attention to, or this board is just a waisting of time?
Very likely wasting time.
U7000 expect SMC communication, to generate PPBUS_G3H.
Some blocks of SMC work, as you get 20V on charger.
This do not assure SMC is in perfect working condition.
