820-00923-A - How to locate a short by injecting voltage into the circuit
imperialboard89
Hi to everyone,
I am facing a short circuit issue on a circuit board and would like to share my situation to seek advice and suggestions from the community.
I have identified the short circuit on the PPVBAT_G3H_CHGR_REG line, and I have proceeded to isolate the circuit by removing R7060 and Q7040. Currently, I am focusing my analysis on the capacitors in the upper right part, specifically from C7050 to C7055 and from C7090 to C7099 (See here). Despite a visual inspection, I have not found any obvious physical issues under the microscope.
To proceed further, I plan to inject current into the short-circuited line. I want to clarify that I have a Thermal Camera. However, as this is my first time performing this procedure, I am uncertain about the voltage and current settings on the power supply. Considering the nominal voltage of the line is 13.1V, I am thinking of setting the voltage to that value, but before proceeding, I want to ensure the correct setup.
I appreciate any advice or information you can provide on this matter.
Thank you in advance.
P.S. I have also replaced the U7000 chip, but the short circuit persists.
Remove F7000 and see which side the short remains.
BTW, what is the exact value (ohm scale) of the short?
About voltage injection, read this:
NO!
Didn't read corresponding information on that link?
Check if any big coil gives you the same reading to ground.
"Be sure first is safe to inject voltage there; read the forum, if you are not sure!"
Seems that you didn't read full post...
How much voltage did you inject?
Your CPU may be dead now.
imperialboard89
I started gradually with voltage:
  • on PPBUS_G3H I putted 10A and 1V, then I tried with 2A and 10V and found the short.
  • on PP5V_S4 I putted 5V and 1A, no more than this.
I thought that is there maybe still a short somewhere, could be?
