820-00923 no activity on ampmeter
dudipupan
Hi there,
after some time of inactivity i'm back :)
I got some problem with an MBP 2017 4TBT here.
It doesn't show any signs of liquid damage but was obvisously opened before.
First step was checking amp and voltage with ampeter but there the charger does not even turn the ampmeter on - on all 4 ports.
I aready tried a known good charger and a known good USB-C Connector.
I would be very thankfull for some ideas wha could be the problem here.
Thank you
First check input fuses; F3000/1 and FB200/1.
Next check diode mode to ground on CC1/2 pins of all CD3215 chips.
Remove USB-C connectors and inspect their terminals for corrosion.
dudipupan
Thank you for your reply :-)
The input fuses are all good.
For the CC1/2 pins i got the following mesurments (in ohm):
USBC_TA_CC119.0
USBC_TA_CC215.0
USBC_TB_CC17.7
USBC_TB_CC2127.9
USBC_XA_CC119.3
USBC_XA_CC24.1
USBC_XB_CC12.0
USBC_XB_CC215.0
dudipupan
Sorry, you asked for diode mode measurents. Here they are:
USBC_TA_CC10.031
USBC_TA_CC20.024
USBC_TB_CC10.014
USBC_TB_CC20.197
USBC_XA_CC10.031
USBC_XA_CC20.007
USBC_XB_CC10.004
USBC_XB_CC20.025
dudipupan
Yes, all terminals ae looking good - no corrosion or dust or any damage.
So I should start replacing the CD3214 Chips...?
