820-00923 no backlight
Kyle93
Arrived with no liquid damage. Works fine with external. Already tried new screen.
Replaced U8400 and Q8400. Surrounding components are good.
Only 0.45V at BKLT_EN_R
Where to go from here? No shorts found
Check diode mode to ground at both pins of D8410; w/ and w/o screen connected.
EDP_BKLT_EN missing too, no pulse in the first seconds?
Be sure R8442 is good.
Kyle93
d8410 pin 1 0.792 pin 2 1.105 with screen pin 1 0.792 pin 2 1.098
EDP_BKLT_EN missing. pulse of 0.80V in the first seconds
R8442 is good
The new screen is known good working?
EDP_BKLT_EN comes from PCH.
If you get image, LCD is detected and PCH should enable backlight.
