820-00923 no power
Kyle93
This board has no power and just randomly died according to customer. No liquid damage.
Meter is at 20v 0.15 amps. PPBUS is 13v. Tried DFU but cannot get the machine into DFU mode.
What should be checked next??
This is not T2 machine.
Do you get 3V3_S5/SUS?
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
Kyle93
Yes 3.2v on 3V3_S5/SUS
PM_PWRBTN_L is 3.3v and has a drop pulse when SMC_ONOFF_L is triggered.
PCH side of CPU is warm on thermal cam
Kyle93
PM_SLP_S4_L 3.4 but does not pulse when SMC_ONOFF_L is triggered
Board has constant S5 voltage and PCH is warm
If PM_SLP_S4_L is steady high, then power on sequence is started.
All S3 voltages should be present, like 1.2V for RAM.
If also PM_SLP_S3_L is high, then check S0 voltages.
Check for USB activity and external video.
What is CPU core voltage, after 10-15s?
PLT_RST_L goes high?
Kyle93
No usb activity or external video. Board is at 20v and a consistent 0.14amps
PLT_RST_L 0V
PPVCC_S0_CPU 0V
PPVCCIO_S0_CPU 0.950V
