820-00923 Power button not working.
bjf
This board had a spill around the power button. I cleaned it up and all the pins on the power button connector are functional and reading correct diode numbers compared to a good board. Touch ID works fine. The power button is pulling SMC_ONOFF_L low and I'm measuring that all the way over to R5170, but the computer is not responding. I've checked all the resistors on the line. Everything looks good. The spill was very minimal. SMC_ONOFF_L is measuring 3.4V. Nothing wrong with anything in the circuit that I can find. Is this just the SMC not responding? Not sure what else it could be.
bjf
Yes, everything works normally but the power button has no effect, it doesn't turn it on or off, even though it's pulling SMC_ONOFF_L low.
Disconnect touchID and try with R5225/26 pads.
In fact, disconnect anything from the board.
It will turn on automatically, when charger is connected; just test if you can turn it off.
