820-00923 pulsing S5 rails
ajdoc
Board clean.
PPBUS_G3H 13.05V
PP3V3_G3H 3.4V
PP3V3_S5 and PP5V_S5 voltage pulsing.
lifted one side of L7660 and PP5V_S5 is stable (both side of L7660 stable 0V) so fault is on 3V3 rail?
Diode mode values:
PP3V3_S5 0.350
PP3V3_SUS 0.327
PP3V3_S4 0.326
PP3V3_2V7_NAND_VCC 0.304
PP3V3_S0 0.290
Any idea?
Disabling 3V3_S5, power on sequence breaks.
That doesn't point to a failure related with 3V3_S5.
The problem can come from other secondary power supply, in S3, or S0 state.
Check diode mode to ground on all coils; compare with good board.
BTW, did you test in SMC bypass mode?
