820-00923 touch bar not working
Soji
PP1V8_S0SW_DFR=1.797V
PP3V3_S0SW_DFR=3.313V
DFRDRV_12C_SDA=1.797V
MIPID_CLK_CONN_P=0.534V...
Still not working after changing touch bar 😒
Soji
The system doesn't wake up from sleep, j5250 is badly corroded i did a bypass solution and it's working fine..
I compare the diode mode reading to ground with good board everything seems fine
Do you get the critical update error?
Soji
Yes.. I tried it many times before I could get it done after the update touch bar stops working
Soji
Touch bar was working before
The critical update that pops up when you're about to activate when choosing language
So you've installed macOS, critical update error doesn't appear anymore, but touchbar doesn't work?
You've compared diode mode readings with good board.
What about signals level (voltage)?
