820-00923: Won't bootup, high fan for 5secs, shuts off, then steady high spin
Hello, have a A1706 (820-00923 or 00239), doesn't bootup (no usbC connector pong sound or image on display), but right fan starts out spin high for like 5 or so second, shutoff then comes back on high again and remains on. Left fan only comes on when i leave the trackpad unplugged, so suspect there may also be issues with the trackpad.
No liquid damage, but the laptop was dropped, which is when the issue started. Not sure where to start here as the usual power rails are all present.
The A1706 laptops should bootup even when the keyboard is discounted, right?
All iCore must start automatically, when charger is connected.
Dropped machine is usually a nightmare to repair.
You could have some broken traces, or balls, under some BGA chip.
Disconnect all from the MLB, let only USB-C connected and test USB activity when charger is connected.
The is power coming from the usbc port just no activity. I can power up a usb device, but when I plug in a thumb drive or external drive, I don?t get any activity.
