[820-00928-A] Help identifying blown component
restorehub
I am getting 20.21V @ 0.00A when plugged in. Disassembled and found this component. I have tried searching for this component based on the inscription but I just could get any results. Any help or pointers are appreciated!
restorehub
Thanks! I have gotten the software and the schematic. Would you have a recommendation on where to get a replacement other than from a donor board? As far as I can find the T525B336M016ATE070 is the closest component to the spec available in the schematic. Would this work?
Thank you!
You can get a replacement from older MacBook scrap boards.
Even 68uF/16V is good, if you have space to put it there.
