If PWM duty cycle changes when press backlight keys, denotes the PCH works good.
The LCD assembly doesn't receive correctly this signal, or you have a problem between U8400 and LCD assembly.
Check for reaction on SCL/SDA lines at same time with PWM signal.
All is good now works fine C8462 had internal crack which didn't show visually and also there was no short but while I was replacing the diode and other ICs it cracked and showed I just replaced it and it worked Thank you very much for your help
