820-00928 A1707 No Display
I think 820-00281 is the closest schematic/boardview for your board.
In this case, GMUX U9850 is fried...
iambehr
Hmm.. source? I read the datasheet, and my admittedly poor understanding of the chip design makes me think that it is just a high speed capable switch, and it's outside behavior is controlled by the Dx_SEL pin on the chip.
Or do you mean that the system firmware has to have the proper GMUX chip specified in it?
iambehr
So... long shot but does anyone have any ideas? Customer just asked if he can send it to rossmann's in NY, and I am going to have to make it someone elses problem ( out of my control, he asked me)
iambehr
Sounds like I should have done that in the first place. As always, thank you for taking time to reply.
Don't have time to get a donor, had this far too long anyway and I think the customer is done with us.
Apple is actually trying to make the repair as more dificil possible.
Even charger chips have firmware.
So be aware and replace any chips susceptible to have firmware only with chips removed from identical donor board...
ALB-Repairs
I have a 00281 with this issue. Tried a to replace u9850 from a 820-3787 with no change in symtoms. Ive now pulled the MUX chip of a scrap 00928 and will get back to you with results
iambehr
Thanks! It will be interesting to hear what happens.
(reason for edit: mixed up customers and said something that was not correct)
ALB-Repairs
I Put a u9850 from another 15 touchbar and still have no internal display. I will do some more digging and swap some more parts out until it works
