pp3v3_tbt_t_f is shorted to ground because of a water spill that got under ub000. ppdcin stays at 5v. could this be the issue? i've replaced both cd3215 chips on that side
PP3v3_TBT_T_F comes from PP3V3_S0.
So you have a short there too.
In fact there are many other components connected.
If your short remains on pin 1 of LB190, then yes, UB000 is shorted.
Does the board start without LB190.
Check if PPDCIN pulses up every 5s at least.
That is not a reason.
U7000 can generate 13V with 5V on input; didn't think you why are 2 MOSFET pairs on the new boards?
Just need SMC communicates with the external device which only generates 5V as normal.
If SMC cannot talk with the charger, it will also block U7000.
If UB000 is involved in the communication, no way to start the board.
