820-00928 TouchID issue after U3900 replacement
Hello. I have a 820-00928 board that had liquid damage around U4200, U3900 area and PPBUS was shorted to ground inside the board under Q3501. I was able to dig the short out and replaced Q3501. I cleaned and replaced a bunch of corroded resistors around U4200 also and the board turned on and booted to the OS fine. The touchbar was on, but it was not responding to touch. I reinstalled a fresh copy of big sur on it but it was still not responding to touch. I did confirm that touch ID was working after reinstalling big sur on it. I found that pin 15 on J4402 was OL, so it was not connected to U3900. I removed U3900 and confirmed the trace was broken. I ran a small wire under U3900 to reconnect this trace and also had to replace U3900 with one from a donor, because I found the original U3900 was damaged. I replaced it with one from the same model donor and now it boots and touchbar responds to touch like it should, but now touchID does not work. When I try and add a fingerprint, it gets to the point where it asks me to place my finger on the scanner, but then it immediately says it failed. I know the touch ID button is paired with the board but is it paired specifically with U3900? I already tried replacing U3900 again with another one to rule out bad soldering, but I have the same issue still.
You've tried to avoid bad solders, but are you sure there's no other broken traces?
Schematic makes reference to MESA EEPROM.
Not sure if that is U3901; just in case, swap the one from the same board where you've got the Touch ID.
