820-00967 - LED 1 only
Palhano
iMac won't turn on, only LED 1 lights up!
The logic board had a short on the 12V line. I discovered it was QD330, replaced it, and fixed the short.
There was oxidation on C5913 and Q8510. I replaced everything, but to no avail.
The PP0V85_ENET line in diode mode has a value of 0.080. I lifted the L8510 to isolate an area. On pin 1, I get 0.500, and on pin 2, I still have 0.080. Can you tell me if this measurement is correct?
I'm using XinZhiZao's schematic!
Do you get any pulse on other LEDs?
Also check for pulse at 12V_S0 and other secondary power rails.
Remove the CMOS battery, to allow automatic turn on.
I have no pulse on the other LEDs.
The 12v_s0 line is stable at 12v.
I have stable 3v3_G3H and 5v_g3s, but I have no voltage on any of the S5 lines.
I'm testing without the battery.
I assembled the iMac to return to the customer, and like magic, it turned on! I'll continue testing and provide feedback.
The device turned on normally. During testing, I restarted and reset the PRAM, and it came back without BKL and the cooler was running.
After the SMC reset, the screen's blackout came back. I ran HWmonitor and it's showing the display sensor triggered. I'll try to find a cable to test it.
The iMac keeps turning on, but again there's no backlight on the screen and the fan is running.
I replaced the screen data cable, but the problem persists.
Any tips?
The iMac worked perfectly for a week. But it shut down during use and wouldn't turn on.
The QD330 shorted again. Any suggestions on what might be causing this short?
