820-01041 5v 50mA no visible corrosion
Outofwhack
ppbus_g3h 12.3v
I noticed that if I have battery connected charger does switch to 20v but zero current flows.
Another board I have only boots with battery connected otherwise the charger sits at 5volts.
So should these boards be debugged with battery connected to allow charger to get to 20v?
Outofwhack
Thanks for clearing that up.
Could I get some guidance on finding the problem with the board. I have a new battery for it so should be able to rule the battery out.
Outofwhack
Im trying DFU and I see 'DFU' on host Mac [even without jumping swk003] but when I click update I get message "Configurator could not perform the requested action. Apple Controller devices do not support this action"
Outofwhack
Ive tried both revive and restore and both timeout with message "The system cannot be restored on this device. Gave up waiting for device to transition from DFU state to DFU state.com.apple.MobileDevice.MobileRestore - 0xFA5 (4005)
I have the board out of the case with nothing attached and finding I get the large DFU icon on the host without having to short the pads to get the board into DFU mode.
Outofwhack
DFU would not work as displayed above.
As a recap the board is stuck at 5volts, 3 USB ports draw around 50mA and one draws zero.
The one drawing zero is the top left (XB) when sat at laptop.
Out of interest when I put an oscilloscope on the clock signal of the flash memory I can see the burst of clock signal when I power the 3 CD3215s that draw current.
No burst of clock signal on the CD3215 drawing zero (XB).
Both signals USBC_X_RESET_L and USBC_T_RESET_L are 0v when powered on X side and T side and there are no pull up resistors to find.
I tried to follow the steps in logic.wiki for CD3215 boot up sequence.
PP3V3_UPC_XB_LDO3.2v
PP1V8_UPC_XB_LDOA1.8v
PP1V8_UPC_XB_LDOD1.8v
PP1V1_UPC_XB_LDO_BMC0v (0.44v diode mode)
HV_GATE10.36v (10.9v seen on other ports when powered)
HV_GATE24.5v (6.7v seen on other ports when powered)
PPDCIN_G3H0v (5.2v seen on other ports when powered)
1V1 LDO can only appear on the powered port.
Compare diode mode to ground on LDO lines of bad port with another port.
Outofwhack
CD3215 XB = U3200
CD3215 XA = U3100
CD3215 TA = UB300
CD3215 TA = UB400
Voltage (when relevant port powered)Diode Mode
PP3V3_UPC_XB_LDO3.20.42
PP1V8_UPC_XB_LDOA1.80.477
PP1V8_UPC_XB_LDOD1.80.443
PP1V1_UPC_XB_LDO_BMC0v0.443
PP3V3_UPC_XA_LDO3.30.465
PP1V8_UPC_XA_LDOA1.80.478
PP1V8_UPC_XA_LDOD1.80.43
PP1V1_UPC_XA_LDO_BMC1.10.451
