Atomrepair
This board has water damage. Someone else put it through an UC, wiping clues, but something remains: J6700 has loose pins for PP5V_G3S_FAN_CONN and PP5V_G3S.
Measurements:
I tried getting the board into DFU mode, but have not succeeded. So far I've tried:
All ports, though focused mainly on the left port closest to trackpad as instructions indicate.
Original thunderbolt cable (with lightning symbol)
Original magsafe charger cable (no symbol)
Belkin cable
another off-brand cable
When I use the non-thunderbolt cables, I get the message ''cannot use thunderbolt accessory. connect accessory using a thunderbolt-capable cable''.
When I use the proper thunderbolt cable, I get nothing. No device is seen in apple configurator. Host machine runs catalina, i'm fairly sure the broken board does too.
I've tried getting into DFU mode both with juse the loose board, nothing attached (this has worked for me on an 820-01041 board from an A1708 before), but I also tried with the assembled device. Is there something else left to try here?
Measurements:
PPBUS_G3H | 12,6V | |
PP5V_G3S | 5,1V | |
PP3V3_S5 | 0V | no short |
PP3V3_G3H_T | 3,3V | |
PP3V3_G3H_SOCPMU | 3,3V | |
PP3V3_G3H_RTC_X | 3,3V | |
PP1V1_SLPS2R | 1,1V | |
PP1V8_SLPS2R | 1,8V | |
PP3V3_AWAKE | 3,3V | |
PMU_ONOFF_L | 3,3V | |
PM_SLP_S5_L | 0V | |
Belkin cable
