820-01041 fans spin no display, no chime, no lights, Short on PPVCORE_S0_GPU
n3vr
OK so I have some knowledge of electronics but not with schematics and this level of components. I am trying to power PPVCORE_S0_GPU with my bench supply but not sure how to find the start of that circuit. I have the schematic and board view open but finding the start of each rail after 12v is beyond me.
I won't ask for anyone to hold my hand but banging my head on the desk at this point isn't working out well. Where do I start and should I even be trying to power this rail to start or do something else. I am getting shorts on 20 or so components and all are related to PPVCORE_S0_GPU when I check them in board view. I am also getting 0.8v on this rail when I believe I should be getting around 1.1-1.2 if I am not mistaken.
Thanks.
Edit: PPVCORE_S0_GFX_PH1 also shorted which I am assuming comes before SO_GPU.
Edit2: Ok I'm stupid CPU rail also has a short. I am working backwards here when I think I need to work forwards. Not sure where the hell to look to find trace down where it all begins.
First of all, welcome to the forum.
Wht didn't post the exact ohm value for these "shorts".
Do not assume so fast a short; CPU/GPU power rails have very low values as normal.
n3vr
Short to GND is around 1ohm on these 4 or 5 caps near the GPU and goes up from there as I move outward. Ranging from 4ohms up to 50.
Thanks for your time.
Edit: they're actually showing 0.8 but my probes read 0.4 so I suppose its closer to that actually.
"1ohm on a cap?"
Why not, if that cap is on CPU/GPU VCORE???
i7 and newer CPUs have very low values...
n3vr
OK so should I start with DFU you think then. I don't own another mac so I would need to procure one. I don't see any other signs of faults and all rails are present. Fans spin etc. No lights however.
n3vr
OK so I finally did DFU restore and afterwards I still got no display but just to see I tried to blindly boot it into target disk and it showed up on my host machine. So I then got a USB C hub and it shows video on external display. So I am unsure where to go from here as I don't have a display to test it with and not sure if I could even find one. And I don't want to order one and send it back because...ya know that's kinda shitty.
