820-01041 GPU Kernel Panic
SoloHarty
We have an 820-01041 in for battery replacement, customer states that it would just shut down when loading on battery and randomly shut down when not on power. Found when loading that there is kernel panics relating to AMD setpowerstate and when leaving the Mac to sleep it will reboot. I’m assuming this is a failing GPU. Is it confirmed that the GPUs in these are at fault and not some component like the old tantalum capacitor on the old 17” MBPs?
Nobody reported such issue similar with old models, for these machines.
Also new CPU/GPU power supply chips (SiC/FDMF) are not recognized failing like old FDMF6808.
You should really have a bad GPU in this case...
