820-01041 Only boots in safe mode
No-Clean
Clean board no corrosion.
T2 was restored and clean install of MacOS via internet already done.
Mac only boots OS in safe mode, normal mode bar gets stuck and or after loading about halve way the bar and all else disappears and nothing happens after that.
Board was tested on a known good separate case with different screen and everything, same problem there.
You may have GPU problem.
Try to install Windows and check if crashes when installs graphiccs driver.
No-Clean
Thanks, would this graphics install happen after windows is installed via bootcamp or when I try to install bootcamp drivers?
