No-Clean
Board had a short on C9588 from some corrosion, U9580 was also shot, after replacing those board gets up to 20v and 0.48a but comes back to 20v and 0.01a, while trying to start I can see that all NAND chips and T2 heat up a bit while the board is near 0.48a, the information on this board is important.
I'm just now starting to use the oscilloscope
When I check L9581 on the oscilloscope it works fine once the board has the 20v and even when it goes down to 0.01a, L9580 only works for a few seconds after the board gets 20v then it stops, both have the expected 2.5v
