It seems like sometimes more likely to crash while stressing dgpu but other times I can run video, valley software and external display until battery is dead. I think more likely to crash while charging than when just battery. Is there any reason you can think of that would make sense? Something in charging circuit / voltage fluctuation occasionally causing kernel panic or something?
Yeah seems as though it doesn't work with Ventura/A1990 anyway. Well in regards to my case, I buried the MacBook for 20 plus hours and it hasn't frozen or crashed but it does still spin fans up if you force it off which gives me good reason to believe it still has issue. Any advice? I think the battery I got from IG isn't the best and going to try one today from MS just to see but seems like the board has some nagging issue.
